It is currently Mon Aug 04, 2025 11:25 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Tue Apr 07, 2009 8:11 am
Thought I'd show my copy.
Maple jaws, walnut for the rest, and leather sling. I added a couple of more kerfs for a greater range. Nice addition to the shop.
Thanks Rod,
Joe
PostPosted: Tue Apr 07, 2009 8:29 am
First name: Chuck
Last Name: Hutchison
City: Houston
Cool idea Rod. You're a Genius. Stew-Mac would sell that for about nine thousand bucks.
Hey Joe! man, you really got on the ball. Looking good.
Thanks for the idea, now I'm going to have to go make one.
PostPosted: Tue Apr 07, 2009 10:16 am
Here's my version... thanks for the "spark" Rod!
also my homemade version of the "relief gauge". This thing has been very enlightening.... thought I was setting relief ok 'till I used this...I wasn't!
Milton, ON
PostPosted: Tue Apr 07, 2009 11:30 am
First name: Chuck
City: Houston
Great Dave.
Dave and Joe, how are you making your wooden knobs and keeping them tight on the metal rod?
Looks cool.
Hutch
PostPosted: Tue Apr 07, 2009 11:38 am
Hey Hutch, my knob uses a threaded insert similar to a t-nut, an odd item I found in my junk drawer, and 5/16" all-thread. Simple cut out wood knob.
Joe
PostPosted: Tue Apr 07, 2009 11:52 am
Thanks Chuck. That's a simple "nut-type" knob....basically, counterbore hardwood dowel into the "handle" material, glue in the dowel & centerdrill (or step-drill) for a T-nut on the outside of the handle. Used 'em for years. The other type I make, a "bolt-type" knob, usefull for bench hold-downs or about 50 spool clamps I made, is essentially putting a knob on the end of a carraige bolt..... shape a "knob" & c'bore for a dowel a bit larger than the bolt head. Then finish drilling through the knob to the bolt thread size, mash in a carraige bolt so the "shoulders" under the headleave an impresseion....deepen these with a chisel (so the bolt won't turn within the knob) insert the bolt and glue in a piece of dowel & sand flush.
Milton, ON
PostPosted: Tue Apr 07, 2009 4:24 pm
First name: Chuck
City: Houston
Brilliant guys, just Brilliant!
Learn all kinds of neat little tricks here.
Thanks a million!
PostPosted: Tue Apr 07, 2009 5:14 pm
You could just tap the hardwood too and skip the inserts. Not that much pressure in this case.
PostPosted: Wed Apr 08, 2009 5:30 pm
Rod...Here's my version. I attached the vise to a 2x4 and attached the assembly to my bench with bench dogs. Like Joe, I made my own knob out of some decorative scrap from the Shredder project. I glued on some leather to the jaws and then slid PVC tubing over the carriage bolt.
I also added some channels to accommodate a nice location to store nut files during the nut slotting operation.
It works as advertised...check it out.
Thanks again for sharing the design!
PostPosted: Wed Apr 08, 2009 5:39 pm
I like the file index slots. Maybe some small draws on the other side for some nut and saddle blanks and other items.
PostPosted: Wed Apr 08, 2009 5:55 pm
Nice one Rod.
I took one look at that thread and could just imagine what might happen?
I thought of a finger out of an old glove, snip off the end and you're set.
I'd show mine but you've all seen a block of mahogany with a sponge laid on top! beehive
A piece of hose is a good one, I really wish I'd thought of that. :oops:
PostPosted: Wed Apr 08, 2009 5:56 pm
Where's the cup holder JJ?
TJK
PostPosted: Wed Apr 08, 2009 6:27 pm
TJK
Terry...I would expect you to understand...lots of design work on orthopaedic instrument cases.
BTW...my cup holder also has a bench dog attached...fewer spills that way!
Users browsing this forum: pullshocks and 33 guests
